76 hunter shaft diameter?
22
Hunter 30 Oyster Bay
Looking to put a new zinc on the shaft. Can some tell me the diameter. I will be doing this in water.
Thanks in advance.
May 21, 2009
362
Hunter 30 Smithfield, VA
My 79 30 has a 1 1/4" shaft, or maybe 1 1/8 - I forget now, but it is definitely larger than 1". I'll just have to measure it again before the next zinc.
Jun 2, 2004
5,802
Tom, how soon can we get a measurement? It would be very unusual for your '79 to not have a one inch shaft. Because of your post I searched further. I found three owners, a '76, a '78, and an '80 all with one inch shafts. And because the bigger boats all had one inch shafts it would be odd for an H30 to be 1 1/8" or 1 1/4".
May 21, 2009
362
Re: '79 H30
Dang
I was at the boat tonight, but hadn't checked the site in a day or two and didn't see your post Ed. I have a 3GMD Yanmar in there which I am pretty sure was not the original engine, so the PO that did the re-engine may have upped the shaft size too. Upon reflection I'm fairly certain I measured 1 1/8." I was using a ruler and checked it about a dozen times because I was having the local diver put a zinc on while he was cleaning the bottom, but of course a ruler isn't as precise as calipers. Still, 1/8 inch is more than a 10% increase over 1 inch and should be readily measurable with a ruler. In any case, I'll recheck (hopefully tomorrow) and report back. I'll put a crescent wrench or something on the shaft and measure the gap too rather than just try to eyeball a ruler.
Jun 2, 2004
5,802
We are all waiting Tom. Do you wanna' wager a little? :) The reason I am confident is that a shaft change would require a new strut or boring out the old one to accept a larger cutlass. But if I was always right I'd be sailing a new Hunter.
bgrube
Mar 12, 2009
12
Pearson 365 Ketch Holiday Hill Marina, Mayo, MD
My '80 H30 has a one inch diameter shaft.
Jun 21, 2007
2,118
Included in the 3-ring binder containing the Hunter Cherubini "manual" for my 1980 H36 is a page that has the propeller and shaft specifications for all of the Cherubini Hunters. The H30 is listed as 1" bore.
