Partial Hard Dodger
I have designed and built a partial hard dodger for my 1982/83 hanter 27' I bought a sheet of 3/8" thk. white starboard which is a compressed copolymer board marine grade, a 1/2 sheet of 1/8" smoked lexan both for under $200.00, I made a template to fit around the full coaming, with openings for the sheets and halyards to get into the cockpit, the lexan windows slide up and out for better ventalation, I added a 1"x 3/8"b rib along the top edge, so that i could install a 6 ft. extrusion which looks like a #9 with a open slot on the top to take a 3/8" dia. yacht braide mounted on my bimini, mounting the partial dodger was tricky, i bought 4 aluminium electrical chassis in a scrap yard, for a dollar, they had 4 1/4"-20 pressed in stainless nuts, so i cut the chassis to make nut plates, I also made angle blocks from the starboard, and screwed the nutplates & angle blocks to the coaming 12 places, To complete the job I designed and had fabricated a 2- 1" dia s/s tubing solar panel rack that attached to my stern pulpit, and 2 verticle bars t5o secure my pedestal, the rack was $300.00 the bimini $90.00 and the partial dodger with all the hardware $215,00, try to get a rag dodger for that price, if you are interested write to Tom Manalili c/o TRACY'S COVE MARINA 1740 HARBOR PLACE SOUTH PASADENA FLA> 33707, and I'll send you drawings and photos.
