7.3 Front Hatch Replacement
StanFM
Jun 26, 2012
276
S2 7.3 Lake Pleasant, AZ
When I bought the boat in February the front hatch was toast. Split completely in two.
I decided to just replace it, rather than affect a repair, even though plexi can be expensive. Professional Plastics has a warehouse near me so I just went there, although they are on the web as well. The shipping can be quite a bit for this sort of large and heavy item. The 30" x 30" x 0.5" square cost me $108 including tax.
I have a combination blade in my table saw, and I used it to cut the straight sides. Take it slow and it will cut nicely. In fact, I trimmed it again where the plastics company cut it off, as I liked my cut better than theirs. For the two angled cuts, I decided rather than to make a jig to use on the table saw, I would just take a small dovetail handsaw and cut them by hand.
Then using a little mouse sander and 220 grit paper, I smoothed and slightly beveled the sharp edges. I rounded the corners a bit as well, and then with the 220 sandpaper, frosted one side of the plastic so the hatch will let light through but it will not be see-through. You can see the paper backing in this picture showing through.
Here's my scrap test piece after trying the 'frosting' technique.
We used the old hatch to mark all the mounting holes in the new piece. The technique I used for the hinge holes which were way too close to the edge for my comfort as they were 1/4" I think, was to drill pilot holes increasing in size, and then as I got closer to the big diameter, I put the drill in reverse, and bored the holes with the bit going backwards so it would sort of melt its way through the plastic, rather than grab and split.
On the boat:
Stan
Feb 22, 2012
34
S2 8.5 1983 Seattle
The hatch you replaced was also home made. The original may or may not have been tinted, but it most certainly was heavier than 1/2" (that's probably why it was split!) and would also have had teak strips to offer some traction when stepped on. Nothing like having a 4 square foot ice rink under foot when your working on the foredeck! The strips also lend an expensive looking touch to the aesthetics.
Feb 22, 2012
34
S2 8.5 1983 Seattle
That 7.3 is really one of the coolest, best looking 24 foot boats ever! Enjoy it! I remember now, I bought a new S2 6.8 in 1978, and the forward hatch on that, though small, still had no traction strips on it. No lifelines either..... Still, today, I really like the idea of not having a big slippery spot in the foredeck.
Sep 17, 2017
15
Pearson 28-2 washington nc
Despite another poster's claim that your broken 1/2" hatch was also home made, I can assure you it's original. Mine was original before getting broken. It was 1/2" and was not frosted. The teak traction strips mentioned were not on the smaller S2s, such as 7.3, 6.9, 6.7 and 7.9, only on the larger ones such as 8.0, 8.5, 9.1, 9.2 etc.
Also, to keep water from creeping to, and possibly through the gasket, I routed a 1/8" X 1/8" groove on the underside about 1/2" in from all four edges, forming a drip edge.
