The OEM folding bulkhead table was a bit tired and needed some help...
...and I just happened to see an article in Good Old Boat about a guy who made some shelves to go behind his table. So, I thought I'd give it a try, even though I'm not a master woodworker by any stretch.
I bought a 4' x 5' piece of 1/2 inch birch ply. Here's the raw pieces coming together...
I decided to make the table pieces a bit wider than original, but a bit shorter to compensate for the added depth of the shelves. I was able to use the original legs and piano hinge, although the hinge had to be cut a bit shorter.
I used a teak stain and varnish. Here it is laying on the floor at the house...
Two table halves opened...
Bottom of table pieces...
Wood gizmo to hold table instead of the stock metal rod...
And top behind the folded up table leaves...
Can't wait to screw it to the bulkhead and give my coffee cup it's rightful place of honor on the boat!
