6hp Chrysler 150 sailor outboard starting issues
Jun 9, 2020
4
O’Day 23 Felters
Hey Guys,
Picked up an Oday 23. Trying to get the motor started to put in the slip. Having starting issues. Replaced the spark plugs. Compression is around 120. Has spark.
May 22, 2020
76
Catalina 22 Iowa
I had an issue with the outboard on my Catalina 22. I replaced the fuel line, all good. Good luck.
Jun 9, 2020
4
O’Day 23 Felters
Thanks for the reply. The quick connect fuel line oring was bad. Replaced. Also needed to give it gas in neutral.
