Hello MaineSail,
I toasted by 4Ds this winter due to neglect. Kind of stupid but I wasn't paying attention because I planned to replace them anyways before we head out cruising. Biggest issue was when I put them in series they weren't age or wear match and were a ticking time bomb. Oh well.
I plan to replace my 2 4Ds that are in series as my primary bank with 4 6volt golf cart batteries. I also have a group 24 12volt as a reserve battery. I plan to use the Duracell EGC2 from Sam's Club as my 6 Volt batteries.
I know I need to make sure I get all 4 date matched for best results in this type of use.
I wanted to make sure I am planning to wire them correctly. I have attached a wiring diagram on how I plan to do the work. I have 1/0 gauge tinned wire I plan to use for jumping in between the batteries. I think I have the wiring correct on how to have them in parallel and in series to give me the full Ah at 12 volts. I also wanted to make sure I had the battery monitor wired correct and the temp sensor for the shore power charger on the correct post.
Also, do you know the Peukert exponent for these batteries? I know you recommended them in the past so I thought you might have that info.
Could you please let me know if you see any problems with how I plan to wire these or if you have any other recommendations.
Thanks,
Jesse
Thanks,
Jesse
