6 Volt Battery box thoughts....
May 23, 2004
3,319
So I am doing a big electrical job to my Compac 23 this spring. I am planning out and I have posted many of my plans.
A late arrival is the pan to go with two 6 volt batteries in a series instead of two group 27 deep cycle batteries. Honestly, reading up on this and hearing what Mainesail said about this has sold me on this idea.
I will be adding the batteries back to the factory original place, the starboard lazzerette. I have talked to the builder of my boat and had advised me that they do make some Compac 23s with 2 group 27 batteries in this location and the extra battery won't hurt the boat's trim in that location.
All that has been settled....Two 6 volt batteries, wired in a series, and placed in the Starboard Lazzerette. They will be placed correctly with the positive sides to starboard and the negative sides to port. Still, I will have to buy or build a battery box.
I am debating on building a battery box out of marine plywood. If I do this I am also considering moving the battery on/off switch from the cabin (there wasn't one originally and the p/o placed it in the cabin in an okay location) to the side of the battery box. This will shorten the wire runs a bit.
The upside would be that there would be shorter wire runs to the switch and to the fuse panels. The down side would be it is a switch in a lazzerette and I would be slightly less convenient.
Which solution is better? Build a box and move the stitches or buy two cheapo plastic battery boxes and keep the switch in the current location?
Let me know what you all think. Thanks.
May 23, 2004
3,319
Oh...and if I fabricate the box, I could add some other stuff to it too. I was thinking about putting hooks to hold the docklines and other things. Still, I am considering expense and convenience too.
BO, the right answer is "What will be most convenient to use?" A little extra wire...I know you're on a tight budget, but it's either a longer #4 wire from the battery box to the switch then to the DP, or the same wire from the switch to the DP, no? Another reason why wiring diagrams are such a help. I just don't understand the tradeoffs...:) If it's simply an I/O switch, wiring shouldn't matter, it'd be the same no matter where you put it...:redface:
Feb 6, 1998
11,772
Building a box is easy and if you want you make it acid proof, as it should be, drop it at your local Rhino Liner and they'll hit it for $25-$40 or so..
If you want to save time Sailboatowners.com has the excellent Dyno battery boxes. They make one to fit two GC2's..
SBO BATTERY BOXES http://shop.sailboatowners.com/prod.php?4651
Jun 6, 2006
6,990
1/4" plywood and fiberglass worked for me. made a box for 4 - 12 volt batteries for the cost of about $20
Apr 8, 2010
2,251
Yup - That's the one
Except for not having the cool label on the side that looks identical to the box I bought from the local Trojan battery shop many years ago to hold two GC batteries where a couple of group 24's used to live. Good quality. I could build one with some 1/8 inch ply and a layer of cloth on each side, but epoxy costs money too... I doubt I would have saved the cost of the commercial box. Measure carefully though before you buy.
Happy AmpHours,
Loren
3,319
I just got nailed by the thought that I have to fit the box into the lazzerette opening. That puts a damper on building the box I was thinking about.
I will probably have to go to two battery boxes and strap each one down to the battery platform. It just makes more sense because it is a smaller opening.
This also means keeping the switch where it is.
Does Costco actually carry the 6V batteries and are they the same as the Sam's Club boxes.
I do have to give a lot of credit to Mainesail's site on this modification. It has convinced me that this is the best course of action for what I am doing.
Joe
Jun 1, 2004
8,346
I believe this information is available on a store by store basis. Your easiest course of action would be to call the store in your area for stock info.
Feb 6, 1998
11,772
As far as I know the Costco/Kirkland batteries are still Johnson Controls/Interstate batteries. JCI batteries are on the lower tier/end of the quality range but all 6V batteries are fairly decent.
About half the Sam's Clubs in the US sell the Deka / East Penn brand of 6V batteries. They are a notch up from the JCI product but are getting closer to Trojan T105 pricing lately at about $109.00 each for a 230Ah EGC2. I can buy Trojan T105's for about $135.00 up here but in Florida and other parts they are even less $$.. Check your local battery distributor who supplies your local golf courses before you buy the JCI battery..
