So I am doing a big electrical job to my Compac 23 this spring. I am planning out and I have posted many of my plans.
A late arrival is the pan to go with two 6 volt batteries in a series instead of two group 27 deep cycle batteries. Honestly, reading up on this and hearing what Mainesail said about this has sold me on this idea.
I will be adding the batteries back to the factory original place, the starboard lazzerette. I have talked to the builder of my boat and had advised me that they do make some Compac 23s with 2 group 27 batteries in this location and the extra battery won't hurt the boat's trim in that location.
All that has been settled....Two 6 volt batteries, wired in a series, and placed in the Starboard Lazzerette. They will be placed correctly with the positive sides to starboard and the negative sides to port. Still, I will have to buy or build a battery box.
I am debating on building a battery box out of marine plywood. If I do this I am also considering moving the battery on/off switch from the cabin (there wasn't one originally and the p/o placed it in the cabin in an okay location) to the side of the battery box. This will shorten the wire runs a bit.
The upside would be that there would be shorter wire runs to the switch and to the fuse panels. The down side would be it is a switch in a lazzerette and I would be slightly less convenient.
Which solution is better? Build a box and move the stitches or buy two cheapo plastic battery boxes and keep the switch in the current location?
Let me know what you all think. Thanks.
