6 volt batteries - Almost perfect fit
My 1999 C36 Mk II burned out one of the original 4D's with a bad cell last summer. I replaced it with 2, 6 volt golf cart batts from Sam's Club. They fit fairly well next to the other old 4D, but are a little higher and longer. They no longer fit in the battery box and the wooden cross beam holding them down had to be left off. They are wedged in pretty well under the aft seat, so they should be safe for anything short of a knockdown past 90 degrees. I intend to strap them down this year. The advantages are mainly price and being half the size, easier to move on and off the boat. I think the total amp hrs is only a little higher than 4D's but they are rated for many more cycles and should last longer. They were cheap enough to experiment with, and I can always go back to a 4D in the future.
