I bought a 1993 Nissan about a month ago. When I bought it, I ran it in a tub and it ran great so I went ahead and bought it. When I got it on my boat and put the boat in, the motor ran great, and still does, in neutral. However, the motor wants to stall when ran at higher speeds in forward. First three times out I was able to get out and back to the dock running at about half power. This weekend, ran great for about 30 minutes then couldn't get the motor to stay running at low power in gear. Still runs great in neutral. I am trying to trouble shoot without taking to the shop or tearing apart so I can make it out for Memorial Day weekend. All marinas I spoke to say it sounded like a carb/fuel issue. Did some work and here is what I found and am going to correct:
1) Emptied fuel out of the tank and had 5%-10% water in the fuel. Completely emptied the tank and left open for a while to let any remaining gas in tank evaporate.
2) Checked the spark plug- the plug was loose (I was able to twist out with my fingers) and the spark area was pretty gunked up. Bought and will put in new plug
3) Upon the marinas recomendation, purchased Quickleen to run through the engine. Planned on running this throught to clean the carb before putting my mixed fuel back in.
Really want to get out next week but marinas cant get in to repair the carb. Do these steps sound logical in fixing the problem? Trying to determine if I should gamble with the motor and likely take it in to get the carb rebuilt when I can have quicker turn-around.
Thanks for the help.
