Jim Nixon
I have just changed the oil in my 1979 30' Catalina with the 5411 deisel, I used a suction device and I think that where the tube goes down the oil dip stick has punctured the oil pan. After a few days when I started the motor the oil buzzer was coming on at idle, I checked the oil and it was low, upon further investigation it was leaking thru the oil pan by the oil dip stick tube!!:=(.I was told that water in the bilge eats the oil pan and makes it weak and suseptable to leaking.Has anybody run into this? Is the pan worth fixing or do I look for a replacement engine? is there an outlet for new 5411 motors and or parts?? I do not know if the motor has been rebuilt or the history of the motor but it seams to be in good condition, (we just went 172 miles on a trip to Catalina and back under power and no problems (thank God).Any advice will be graty appriciated as I will start pulling the moter in the next week or so.
