C
Chris Gonzales
The AMP meter needle on my 5411 Universal diesel engine shows only a very slight inclination into the positive charge area when my engine is running. With engine off and the blower switch on it shows a little more discharge on the meter than that but never shows discharge when running. I have used the motor little since buying the boat and have charged the two batteries at the dock with shore power, so how the batteries are charged isn't a good indicator of the engine charging them properly.Can anyone tell me how to test the alternator for charge? It is difficult to tell what wire is what and the thing has been painted a few times. Also, when charging the batteries with a charger using shore power, is it critical to disconnect the ground to protect the alternator diodes?Thanks!Chris
