This past weekend, I learned my alternator was having issues when I got the low battery voltage alarm on my VHF command mic. Investigation revealed that a wire (the orange one that leads to the battery) had burned through.
Quick checks while underway was showing an output voltage off the alternator of ~16VDC, but a second check while inport (and not on a rocking boat) showed no voltage.
I'm going to go out on a limb and guess it's a bad alternator - does anyone know of a resource to rebuild or replace one? I have had no luck searching the part number out of the manual (a 55A model), though I have seen a few 51A models that are nominally equivalent; I am, however, reluctant to drop $600 on one that won't work with my boat, or if someone in the community knows a better resource.
Thanks!
Thanks!
