W
Warren Feldstein
1)Assuming that you install a full cockpit enclosure, where and how would you mount a Bar-B-QUE?Large dickenson. Has any done it?2) What size ground tackle are people using. If you go to Simpson Lawrence web site and look up what is required for a given size boat, the anchor selection algorithim they use returns a VERY small Anchor. I looked up Delta specs. and found that for a 45 foot boat, they recommend a 35lb. Delta. This sounds ridiculous. What are other people doing?
