45CC Generator Size?
Aug 18, 2024
2
Hunter 45CC Grand Rivers, Ky
I've given up on my 248 hour Fischer Panda generator. Likely replacing it with a Northern Lights. The FP is the 8 Mini. That's about 65 amps, much more than needed if it worked correctly. What size generator do others have? I have two air conditioners, fridge and freezer as the big power hogs.
Feb 10, 2004
4,236
Hunter 40.5 Warwick, RI
For a point of reference - I have two A/C's - 16K & 7K, water heater, separate 12V fridge & freezer, and two 80A battery chargers.
I can run everything simultaneously except for one of the battery chargers on a Westerbeke 5Kw genset. 5Kw is about 42A of 120V power.
Compare your A/C sizes, and make a choice. Remember that the A/C's in heat mode draw a couple more amps than in cool mode.
Likes: Kev's Hunter
Jun 14, 2007
183
Hunter 45cc Florida
Next Gen 5.5 fits in the same space as FP mini 8. A little louder the FP but much simpler and reliable
Dec 25, 2000
6,056
Hi Kev. Our boat has many of the systems as yours. Dual heat pumps, fridge and freezer, water heater, entertainment system, etc. Hunter equipped our boat with an 8KW Onan Genset, using a Kubota three cylinder diesel.
Aug 18, 2024
2
Hello Hunter owners. I have completed the installation of my new Northern Lights 6kw generator on my 45CC. It was a huge job with many connections. I don't want to do it again. It fit just enough to work fine. I have to place a new door on the engine compartment to access the raw water impeller. It powers everything fine. I'm still trying to figure out the routing of the control panel wiring from the nav station to the engine compartment. Any help would be appreciated.
Be safe and have fun.
Kev
6,056
Our 1991 P42 came with an Onan 8W Genset using a Kubota three cylinder diesel. It can operate the two heat pumps, hot water heater, refrigeration, etc., with ease. While out cruising, I run the generator for 1.5 hours every other day to charge the house bank, heat water for showering and some cooking. Works great.
