450 Solar Panel
Sep 10, 2012
231
Hunter 450 Gulfport, Florida
I don't know at what point Hunter incorporated a solar panel between the bridge deck and the mast step. Mine looks a little rough as would be expected baking in the sun for a dozen years. Is there a solar controller for the unit or was it just a trickle feed? Where did they terminate it, so It could be tested to see if it is still alive?
Oct 24, 2011
278
Hunter Passage 450 Lake Lanier, GA
My boat has a fuse located on the wall in the aft cabin near the mascerator buttons and the fuse for the windlass. You could check the output there with a voltmeter.
Sep 10, 2012
231
I will look there to see, I am curious if it still is producing and I didn't want to poke holes in the wire.
