426 DS Sailing Performance
73
Hunter 426 ds Pleasant Prairie, WI
Hi,
This probably is going to seem like a dumb question but I am going to ask it anyway.
We bought this boat in April and are new to the B&R rig. Our last boat was a 27 O'day - big size and weight difference I know. We are cruising on this boat and we love the boat as a liveaboard. You just can't beat the interior volume and accommodations.
Where I have become frustrated is in the sailing performance. The boat just doesn't want to move under sail. For example the other day we went for a day sail off of Boot Key Harbor in Marathon, Florida. We had winds in the 8 to 12 knot range and when we would put them on the beam we were getting 3.5 to 4 knots out of the boat. Current didn't seem to make any difference as we would tack around and get about the same speed the other direction. To really get this boat going - 7 to 8 knots, you need 20+ knot winds just ahead of the beam.
The boat has the Selden in mast furling with the unbattened, loose footed main and standard furling jib. I would be interested in what the other boats in this class can do in these winds - is this kind of performance normal? This is a big sailboat but shouldn't it perform better than that?
I know it's difficult here to diagnose a situation like this but I would sure be interested in any comments and thoughts.
Thanks!
Rick D
Jun 14, 2008
7,207
Do You Have A Three Blade Fixed Prop?
nm
Aug 29, 2010
73
It is you!
But for 7-8 knots yes you need to be in 20 knot wind.
It may well be, but I can't think of what I should be doing differently. We have tried trimming various different ways and have yet to find a solution. Also, we have a flexofold three blade folding prop. One thing I am suspicious of is the tune of the rig. Does anyone know, if a rig was out of tune could it make that serious a dent in your speed?
Oct 1, 2007
1,865
Hi,
Thanks!
I have a 44DS which is the same hull and rig. I have a Max Prop. My sailing perf is very good. I have paced similar size boats in various conditions, except dead downwind where the B&R rig is not very good, and found that we had comparable speed thru the water and better pointing in some cases. Dead downwind is a problem though. One day we paced a J something 40+ ft for about 20 miles and found he gained maybe 100 yds on us in close reaching conditions 10-12 knots, 2 ft seas. My question to you is how are you measuring speed? The paddle wheel is very unreliable unless you have carefully calibrated it. The only reliable test is boat for boat.
Aug 29, 2010
73
Thanks for the response. I have been using SOG. The other day there was a guy in a Tartan 40 that passed us and then tacked around and passes us again - literally sailing rings around us. Totally demoralizing.
Jun 25, 2012
942
hunter 356 Kemah,the Republic of Texas
Sail trim...most cruiser over trim in to tight. Ease sails out till they start to luff and then bring them in just enough to stop the luffing...for best trim always sail on this edge. Slide car back on the jib. So it always has a little twist .
Example I have friend 40 years now... who when he sails with me he wants jack with my sail trim and choke down the jib and main ....the boat will come to and almost dead stop. He just does not get it even after all this time.
Patrik
Apr 1, 2008
66
Hunter 356 Stockholm
My advice is to look at the "engine", ie the sails. Unbattened furling main and standard furling jib used during a couple of years are probably not the best if you are looking for speed and good performance. Contact a sailmaker and get his opinion. Battened furling main and even a battened furling jib will increase your sailing area with at least 15%. I have made that on my 356 and it´s a big difference in speed and performance.
Oct 6, 2008
857
Hunter, Island Packet, Catalina, San Juan 26,38,22,23 Kettle Falls, Washington
If your standing rigging has not been tuned in much more that a year you should have it done. Once that is done you can repeat this process with a "Loos Gauge". It is a not a hard job at all and it makes a VERY big difference in performance. It is much easier on the boat's structural elements. Talk to any rigging shop and see what they say.
Ray
Oct 15, 2012
11
Hunter 420 Colington Harbour
Re. the speed of your 426, 1/2 the wind speed is all you can expect, but, you should get close to that. I assume that you have in mast furling; not great for sailing performance. Sailing is the down side of newer big Hunters. How old are your sails? With out battens, the main will lose its shape gradually and you won't notice. That makes a huge diffence in a battenless main. I had the "belly" cut out of the main on my 420 CC and it did improve performance. Sail trim is critical and I strongly suggest that you trim the sails as perscribebd by North Sail Univerity and then experiment with small adjustments. Another thread said not to over trim and that is good advice. Again, consider the age of your main and if it is several years old with sailing miles on it, get a sail maker to look at it. If you are typically sailing in 8-12 k, you probably will be frustrated with that boat. It needs at least 12 and 15k is better to get going. My boat is a 2001 and is loaded with cruising goodies and she sees only high sixes and low to medium sevens. Yes, it will jump to the low eights in 20+, but, won't hold it. Before all of the additional weight, years ago, she did perform better. Hope this helps.:)
Aug 29, 2010
73
Thanks for all your advice. Fist step is to have the rig retuned. Then we'll take her out and see what we can get. I think I probably do have a tendency to overtrim so we'll keep an eye on that as well. Pretty sure sails are okay, boat doesnt have a lot of hours. Thanks again.
