Daniel, we've had a 1991 for over three...
years and love it. How is the one you are looking at equipped? Ours came with electric heads, 8kw Genset, heat pump in the main cabin and aft cabin, etc. Some things to check out:1. What is the holding tank made of? Ours is SS and has held up well. If aluminum, it probably needs to be replaced. If plastic, you should be okay.2. Manufacturer electrical recall. Ours qualified. Contact Hunter Customer Service with your hull number and they can tell you if the boat is eligible. Labor and materials all free. 3. Engine hours? Genset hours?Great boat. Easy to solo. Midship cleats a must. I had to add them to ours.Terry
