41DS Refrigerator Replacement
Aug 26, 2007
282
Hunter 41DS Ventura, California
Hi all,
The original Nova Kool DC only unit finally quit working (15 yrs old). I would like to replace with an AC/DC unit. There is an available AC outlet in the refrigerator cut out but the microwave uses it. I'm afraid the load with both units would strain the 15 amp circuit. I would like to install an additional circuit/outlet using a spare CB on the AC panel(10AWG marine wire) and utilize the original CB/wiring for the DC feed. Any reason why this wouldn't work?
I am considering a Nova Kool 3800 AC/DC version of the original or an Isotherm Cruise 130 Elegance as a replacement. Any recommendations?
Thanks for any input.
1,860
Hunter 49 toronto
Hi all,
You should have ample current on a 15 amp line to run both.
If you think about it, many households have a full size fridge and a large microwave on the same circuits.
Aug 26, 2007
282
Makes sense. Thanks
JamesG161
Feb 14, 2014
7,935
Hunter 430 Waveland, MS
Both the Microwave and Frig do have a starting Amp pull.
Add those Amp loads up to verify what @artboas said.
Since I design homes, I completely separate the Microwave, since is turns on and off in many programmable functions.
Refrigerators are simple on/off as needed.
Jim...
