Has anyone traced this entire circuit (physically)? My stop button longer works. It has power but the relay is not closing to energise the solenoid. Does anyone know the route the harness takes? I had this issue several years ago and it was the relay. Not that lucky this time. My 410 is a 1998 so it has the fiberglass arch and the engine control panel is in the arch. I believe the harness comes out of the port gull wing locker below the removable deck plate. from there I'm not sure. I had a 340 previously and it had an issue with the start circuit where Hunter had to splice in a section to extend it. It failed there at the splice. I'm wondering there's a similar situation on this circuit.
Thanks
Thanks
