Jim Vincent
My question concerns the raw water supply line from the hand pump to the toilet bowl. it seems this line leaves the hand pump and disappears into the wall(to form a loop above the water line) between the aft head and the nav station and then returns to the toilet bowl. i assume this is done to incorporate an anti-syphon valve so if the hand pump shut-off valve fails, you would not sink your boat. if this is correct, has anyone had a problem with this valve leaking,(i do?). ...short of cutting a hole in the wall to get to it, does anyone have any suggestions. Jim Vincent, Toucan
