4 stroke outboards
Steve Ellis
Has anybody found a 4 stroke outboard that will fit the outboard well without having to make any alterations?
L
LaDonna Bubak - Catalina Owners
Honda
I just bought a Honda 15 hp 4 stroke & it fits fine. Only problem is that it won't tilt up cuz there's no room to spare. I have jeeeeeest enough room to get the cover off to check the oil. LaDonna
John Eastin
Weight?
Hi LaDonna, I'm in the market for a new outboard myself....have been told I couldn't go any larger than a 9.9hp. I trust your judgment...am guessing the weight of your 15 hp Honda must be about the same as a 9.9? Are you happy with it? Any other advice is welcome as well. Thanks!
jamie
outboards
Hi Steve check out the yamaha 9.9 just great and check out the install on kaluha at the townsite marina in naniamo
Debbie
9.9hp or higher??
We've only had our 27' for 45 days, was a fantastic deal, however, we need to purchase the OB.. We have been told anything over 9.9hp is a waste of money and gas...?? Would appreciate any pointers!!
L
John Eastin & Debbie
Sorry for the delay in responding to you John - I didn't see your post. I ONLY got the 15 hp because I was doing a trade with the guy that saved me about $800 (than if I had gone with a 9.9). Go with the 9.9. The 15 & 9.9 are the same motor, the 15 is just tuned differently so there is no weight difference. Take a 9.9 to the right mechanic & he can turn it into a 15. But you really don't need one for a 27. I sure don't. I would have been perfectly happy with a 9.9 but it just happened the deal worked out this way. The motor fits perfectly in the "hole" but I can't lift it out of the water. Checking the oil is a challenge but not impossible and the cockpit controls are to die for! LaDonna
Jeff Galvin
4 strokes for a C27
This is more for Debbie's posting from 10/1/2000. I have a '93 Yamaha 9.9 long shaft that works great, but mine's mounted on an adjustable Garelick bracket on the transom (not in the well). I can't tell you what will work best through the transom.
