bracket replacement
Kevin... I'm in the same situation, needing to replace a tired old bracket on an '87 boat. I will eventually replace my Yamaha 9.9 2 stroke with a 4 stroke and, with that in mind, I have zeroed in on the Garelick #71090 bracket. This bracket is designed specifically for the loads, etc. encountered with the 4 stroke. My 272 also has a "wedge" on the transom, to angle the engine properly, but the heavier constructed 4 stroke brackets are dimensionally larger than the factory supplied bracket and won't fit the wedge. My approach will be to remove the old bracket and wedge, fill the holes where required, and drill new mounting holes on the transom. I don't ever like drilling holes in a boat hull, if possible, but I don't see any way around it. I may be wrong, but I think the bracket can be mounted without using a wedge on the transom. There should be enough adjustment in both the bracket and the the outboard itself to square things up and align the shaft perpendicular to the water. Making a template and marking the hull (measure thrice, drill once) helps me feel comfortable drilling fiberglass. There are marine plywood squares inside the transom and they distribute the load accordingly but, given the weight, torque, etc. of the 4 stroke, I plan to add 1/8" stainless plates (4"x4")to the plywood to further support the mount. Have I missed anything?
