1. I have to change out my entire rub rail. PO must have really smashed it all somehow so anyway, I assume the white plastic piece gets screwed onto the hull (haven't taken mine off yet) so when one goes to screw the new one back on, should he use butyl tape around each screw or some other type of sealant or is this not needed?
2. What is the best thing you have found for taking off old sticker glue? I pulled off all the PO's stickers and decals etc. and now have to get all the glue off. Goof Off is worthless. I told my wife if I could invent a product that you spray on and it just falls off I wouold be a multi-millionaire.
3. Hatch boards. I am getting ready to order acrylic tinted hatch boards from D&R Marine at a toon of $275 + shipping. Ouch but hopefully they will last me a minimum of 5 years. I thought I had found a place online for cheaper but they are all about the same. I think having the extra light over solid teak boards would be nice. Any thoughts?
4. I was going to install a Thetford 550msd Porta-potti which has the deck pump out ability which my boat has already and the vent line however, the 550msd is 16 1/2 inched tall but does have a 5.3 gallon holding tank. On the 1985 O'Day under the existing head, there is a fiberglass piece molded into the boat that is another 6" tall so that would be a totall of a 22 1/2" high head. My wife being only 5' tall would need a ladder to get up there and if I was at rest and had any beers in me, I might fall off myself. I would just make a step but it would be too tight with the bi-fold door and I am sure always in the way. Has anybody figured out a way to do this if they tore out the current sanitation system and went with a porta-potti? I could go with the smaller unit whcih only has a 2.6 gallon holding tank but that is too small even though I have free pump outs I don't want to HAVE to pump out every weekend.
