Hi,
I am going to replace the raw water impeller on my 3jh5e yanmar this spring. In reading the book on this engine it has a puller to take out the impeller.
I have seen YouTube videos that just used two pliers to remove the impeller. I don't know how long the impeller has been in the engine and was not sure if the splines have a tendency to corrode or if the impellers come out easily.
Do any of you out there use anti seize on the splines to help replacing the impeller?
Thanks,
Al
Thanks,
Al
