393 Cyclades cutlass bearing size
Jun 13, 2017
2
Beneteau 393 Cyclades Australia
Hi all
In order to save time and money when the boat is hauled out, I'd like to get a new cutlass bearing ready to go before she leaves the water.
Would anyone know the OD of the cutlass bearing on a 2007 393 Cyclades with yanmar 3jh4e (40hp).
In fact, any technical specs on the boat would be really appreciated. Not a lot available on the net.
Cheers
Jan 5, 2017
2,480
Check your shaft diameter then an online bearing maker. We have a Beneteau First 38, shaft dia. is 30mm bearing book says 30x45x 120 and it's right on.
Oct 15, 2021
1
Beneteau Cyclades 393 Montreal
Hi all
Cheers
Did you ever find out what size was your cutlass bearing? I have the same boat, but I'm out of the country so cannot take measurements. Hoping to order the right part before returning. I'm hesitating between the 25x40x120mm or the 30x40x120mm
Oct 3, 2008
325
Beneteau 393 Chesapeake Bay
I have a 2003 B393 with the larger 55 hp engine, but the prop shaft is standard between all 393s at 30mm. The Beneteau parts website has the same part number for all engines. It's only $55 so that's where I would buy it if it was me.
NYSail
Jan 6, 2006
3,178
Beneteau 423 Mt. Sinai, NY
Second the Beneteau spare parts web site. Thats where I got mine from........ they have all models and all parts available.
Good luck.
