380 Rollers For Running Rigging Under Turtleshell
May 17, 2014
136
hunter 380 Plano, TX
Thanks in advance. I am finishing a refit and while restepping the mast I found that the nylon(?) rollers under the turtle shell are trashed and need replacing. Has anybody else done this and what did you use? These are not the turning blocks but 2 sets of 4 rollers each that simply keep the lines close to the deck. I'll get pictures today
viper
Jul 31, 2016
131
Hunter 380 Cape Coral, Fl
Nobody else has encountered this??
My Hunter 2000, 380 does not have this problem... I would ask HunterOwners store , give them the measurements. get back to us.... with info, its only time before more of us have the problem if you do now. Severl of the parts that the store offers now are parts they got or made for me this past year.
You can also ask Hunter, both will want hull#
Regards,
May 17, 2014
136
Good advice,,,I also need to raise the shell and get a good pic of them
viper
Jul 31, 2016
131
Had mine up last week, only 6 screws if I recall.. oops it was 8. Its also a chance to clean the area, check the seal and etc.
Regards
Oct 27, 2016
0
Seattle
And now a word from the sponsor...
Replacement in-deck solar panel
Finally, a drop-in replacement for the in-deck solar panel on Hunters built from the early 90s through the mid-2000s. Improved for longer life and greater output.
See the product
