Can anyone describe how the hoses from the cockpit drains are routed in the aft end? After finally removing the old leaking aluminum fuel tank, then cutting out the wall behind it, I found the mess shown in the attached photo. Since several hoses were cut or broken off, I can’t quite figure out how new hoses should be routed.
Originally, the port cockpit drain emptied through a small (one-inch?) hole on the starboard aft end, while the starboard drain didn’t – I figured it was blocked with something. Now I can see that the starboard drain emptied into the bilge because the hose was cut off! (And I thought all that rainwater was coming from an infinite number of deck leaks!)
From what I can see, the starboard cockpit drain hose goes to a 3-way t-fitting (grey in the middle of the photo) where the 2nd hose seems to be coming from the manual bilge pump (white ribbed hose) and, although it’s cut off, I assume the 3rd hose went to the hole in the port aft end, while the port cockpit drain had just one hose going directly to the starboard hole. Is that correct?
Another question – there is another hole in the starboard side of the aft end just below the cockpit drain hole – is this for the diesel exhaust? It seems almost too small for that, but there is no other hole back there for the exhaust to go!
Can someone please help my rapidly numbing brain and describe all this to me?
Thanks!
Thanks!
