I'm rebuilding my electric panel, and I found a clipped off wire. I traced it to a keel bolt just behind the mast. Because the wire is 12 awg, and its clipped off, and because the nut on the keelbolt looks like an add-on, I've taken the wire out. Its not in the DC electrical diagram for the 37c...
I'm not sure I want to ground my new Blue Seas 100amp panel
,as all NEG grounds to the engine. I'm curious if anyone else grounds their panel in this way?
(really nasty pre-purchase) Picture of bolt attached. You can see the add-on (rusty) nut and steel plate overtop of what is a stainless steel keelbolt on the right.
I also don't have the 8ga wire noted on the 37c diagram for the mast ground, but the mast base is held down by 2 huge keelbolts, so is it needed? Seems to me the mast can't be grounded any better...
Much gratitude goes out to those on this site who posted the 37c PDF manual. Its Priceless.
I'm still pulling the old electrical tape off wires, untwisting marretts, and muttering "Why, why, why?..."
