37.5 Y-Valve Installation
Bud Cook
I am still wrestling with a head Y-valve installation on my 37.5 (there's so little space!). Is there anyone in the Connecticut area that has this same boat with a sucessful installation that I might have a look at? Bud
F
Fred Levine
One Y valve answer
I have a 1991 37.5. The valve was installed in the rear compartment behind the holding tank. It is easy to get to from the swim platform. The valve is installed just before the waste line exits the hull. Its easy to work in that compartment and not difficult to switch the direction of the valve. Maybe we will see each other this summer when I'm in the Sound the first week of July. I plan picking my way from the East River to Shelter Island with stops at the Thimbles and maybe Watch Hill RI.
F
Fred Levine
Add to previous response
Bud, Sorry I forgot to tell you that if you come to Long Island you can visit my boat and see the installation. If you wish to email me I'm flevine@satty.com.
P
Peggie Hall/Head Mistress
A couple of reasons, Fred...
In fact, I strongly recommend a y-valve instead of only a tee or wye fitting. One reason--the macerator isn't barrier to water rising in the overboard discharge line to fill the tank. A y-valve that's kept in the pumpout direction becomes a backup for the seacock (that too many people leave open, even though they shouldn't). It also allows the macerator to be installed very near the tank discharge instead of above the tank when the tank discharge is below the water line. Why is that good? Because the further from the tank and higher it is, the longer it takes to prime...and the longer a macerator takes to prime, the more wear and tear on the impeller from friction heat. And finally, marine sanitation laws in coastal waters require that a system be secured from overboard discharge while inside the "3 mile limit." Without a y-valve, the only way to secure the tank against illegal dumping is to secure the thru-hull--by wire tying it or removing the handle. If you have a y-valve, which is often much easier to reach than the seacock, all that's necessary is to secure it.
Dec 2, 1999
15,184
Why After?
Fred: The reason for the 'Y' valve after the holding tank is to make the POOP Cops happy. This way they think that you ALWAYS pump into the tank and then you can determine which direction you are going to pump out (either direct discharge/ overboard or thru the deck fitting). Take a look at the West Marine catalog they have a scematic of this system. On the other hand, if you generally sail offshore, you would want to put the 'Y' before the holding tank and then your decision is to either go overboard or into the holding tank! This can really get complicated and cost a lot of hose depending on the plumbing arrangement that you may desire.
