37.5 1991 mast base plate
Nov 30, 2008
44
Hunter Legend 375 Sidney BC
Hi I have a 1991 37.5 new to me this past April. Can anyone tell me if they have added extra blocks to the bottom of the Selden mast on the base plate, if so how are they attached?
Feb 21, 2013
4,638
Hunter 46 Point Richmond, CA
Congratulations on your new sailboat!!
All my halyards, boom vang, mainsheet and continuous furler control lines are run through turning blocks (Lewmas with stand up springs to keep them off the deck in a vertical position) at the base of the mast step then back to the cockpit. If I had reefing lines (and I do not) they would also run through them and back to the cockpit. Each are attached to the mast step hole with a shackle and 2 large diameter clevis pins.
  • Helpful
44
Thanks for the reply. Yes you are blessed with a mast base plate that has a number of connection points for turning blocks.
Mine is not shaped that way. Mine has holes in it but I think the mast needs to be lifted to access them from under the plate.
Hans.
A picture of your mast base would help clarify the challenge that you are observing.
