I'm looking at a 1988 Catalina 36MK1. I'm well aware of Catalina's great reputation. I'm a little concerned with the hull keel joint as it is weeping greenish crust which suggest to me galvanic corrosion. I repaired the hull keel joint on my Pearson which was cosmetic. Is this model known for the same problem? Am looking for all comments as what I should be concerned with this model and vintage. I've had a couple of A-4s but no diesel experience except bareboats. The Universal <1000hrs. Are the stanchions and deck hardware mounted through balsa core or solid glass?
Thanks in advance
Lou
Thanks in advance
Lou
