Zenith
I also was unhappy with the performace of the Hunter supplied UK main. Based on Chuck's and other's reports, I went to the Doyle Sail Loft in City Island, NY and inquired about the swing batten. The folks there told me that the swing batten has been replaced with the Zenith, true or not I do not know but I was not thrilled with the mechanics of the swing batten anyway. After a little thought I decided to order the Zenith main. It has just been delivered to my home, was supposed to be delivered to the loft. The verticle battens are interesting as they go from the foot of the sail to the luff which makes them from about 5 to 20 feet long and about a 1/2 inch thick. Doyle insists that they will furl without any problems - we will see. When I called the loft regarding the delivery mistake they apologized for the mistake but also suggested that I take the battens out of the box they came so they would straighten (they were bent into a 48 inch circle). Doyle will come to the boat when it is in the water in a few weeks and install the sail, that is if I can figure out how to get the battens to the boat. It should also be interesting how to install the battens. Anyway, if all works as advertised and as it appears, I expect to get much better performance as I will now have that large roach and the sail area will increase by about 30% and the battens to improve and hold the shape.I also purchased a UPS (Ulitimate performance Sail?) for the light air days. It is something I guess between a flasher and a spinaker. It comes on a roller furling and you remove the sail and furling gear in one piece when not in use. I am looking forward to both new sails and hopefully have made a good choice. I'll make another posting when they are installed and we get a chance to try them out.Feel free to contact me should you have any questions, I am listed in the directory.Bob Kellersv Kathryn, Stamford, Ct.
