343 Battery Sizes
40
Beneteau 343 Seattle
I'm looking at the new 343. The literature says that there are 2x70Ah batteries. This seems rather inadequate to me. I understand that one shouldn't drain the batteries to less than 50%. If the fridge alone draws 3.5A then that would give me about 10 hours between battery recharges (assuming only one is used for the house). What am I missing here? What's Beneteau thinking here? Pretty roomy boat for a daysailer? Thanks
C
Charlie Gruetzner - BeneteauOwners.net
Additional batteries
Unfortunately, what they give you may not coincide with what you need. I think you are going to need at least one more Group 27 battery and if you have an inverter and windlass at least one 4D battery for them alone Good luck Charlie
Aug 1, 2005
84
Beneteau J-Boat Huntington, NY
Don't Use The Battery For The Fridge
I have rented boats in this configuration, what I normally do is the following ... 1. Get the empty fridge cold by running the engine, this also confirms it is operating correct. 2. Place ice in the fridge, not too much, enough to fill 10%-15% of the volume of the fridge. 3. Supplement ice with running the fridge with the engine running for an hour in the morning and an hour when motoring to your anchorage. If your not moving the whole hour, keep the engine idling at 1600 rpm for the balance. 4. Add ice every forth day. Then your battery usage for the fridge = zero, lots of other uses for the battery. Can't run the engine for the whole hour? ... then your still only using a small portion of your battery each day if you run the fridge for two hours. Note, charging the battery after it passes 85% of full capacity becomes slower, making it very difficult to reach 100% every day, so you really only have about 35%-40% of your AHr rating available to you each day (not 50%)
