Shroud Problems
Hi, Floyd. I think that you will find that the outboard shrouds on the H340 are going to get in the way of a large genoa when you try to sheet in. I don't think it would work well; the boat is really not designed for that kind of a foresail.We also have a 2001 H340, and would probably ask how much you have sailed the boat with the standard 110 jib. Even with the standard 110 jib the H340 has a LOT of sail up there, mostly in the form of that huge main. We found the boat to move well even under light wind conditions. In anything over 12-15 knots, we were into a single reef; in fact, we probably sailed more often with one reef this year than we did with full sail.We would recommend that you give your boat some serious sailing time before deciding to add a 135/150 genoa. I can't imagine sailing an H340 with a 150 up front; unless your sailing area is consistently very light air (<<10 knots), get ready for some serious heeling and weather helm!! IOHO that is just too much foresail for the boat, even without the shroud interference issue.Carl and Jules/v 'Syzygy'
