340 Refridgerator
slr295
Dec 6, 2008
12
My Adler Barbour original gets cold but freezer not cold enuff to make ice
Had tech look it over monitor etc and can not come up with answer
Cooks clean etc
Fan runs
Seems to have coolant
Anyone have this issue??
Sep 15, 2009
6,244
S2 9.2a Fairhope Al
where are you it may be too hot out side where you are or you may need to defrost the refer
Jun 4, 2004
834
Hunter 340 Forked River, NJ
I never tried to make ice in the refrig on my 2000 H340 but mine will keep a bag of ice frozen for the whole summer at a middle thermostat setting of # 5.
Some suggestions: Check the fit, seal and locking of the lid. Check that you are not loosing cold air out of the drain hole in the bottom of the refrig. Every 2-3 years remove the forward cowl from the compressor unit and vacuun the dust and dirt from the coils. Also make sure that both of the fans on the compressor unit are working. Lastly, you can insulate the coolant line that runs from the compressor, under the settee bench to the refrig.
May 24, 2004
7,237
CC 30 South Florida
Seems to have coolant? Have it pressure tested. Another thing you can check is the air flow around the coils. Accumulated dust or any other obstruction will reduce cooling ability.
slr295
Dec 6, 2008
12
Thanks
Mine worked great since 2000
This year fridge cold but freezer just not enuff to freeze water
Cleaned coil
Plug in
Set on highest number
Il try wrapping the coolant line
Tx. All :-(
Jul 29, 2004
413
Hunter 340 Lake Lanier, GA
Re: Thanks
Something is definitely not right. Mine will freeze a tray of ice made from room temperature water in a few hours. We leave ours on from early April to late November in Georgia to keep the beer cold. Setting is about two steps down from maximum or it will freeze cans of soft drinks sitting on the bottom.
