34 Hunter Mast
Jun 12, 2013
213
Hunter 40 back creek
Still looking for the Mast and Rigging for my 84 Hunter 34 I have located a foot from the earlier 83 which is different than my original low profile foot that held the blocks inside the mast and of course this would change the rigging if I got a mast without the blocks inside but the rigging if it came with the mast should work. Any ideas on this
Oct 14, 2005
2,191
Healer...
You're going to have to make a choice because of the difference in the mast bases. I like the black base the '83's have as it appears to be a lot more substancial than the later models' sticks. The blocks in the mast design appears to have been unique to the later H34's. More likely to find a straight mast if not from an H34, so the black block base may be needed.
Dec 14, 2003
1,442
Re: Healer...
Like Dan says, you will need to make a choice. FYI on my 84 (small mast step and blocks at base of mast), I was able to easily fit a Charleston Spars mast when I broke the original Kenyon. Same height and same oval shape. Only changes necessary was a little filing at the front of the base mast. Looking at different brands and measuring them may enlarge your search and speed up finding a mast that fits. Good Luck.
Jun 12, 2013
213
Than you guys, good advise. Now the mast question is answered and I purchase a new mast. I have to search out double spreaders and rigging. I forgot to mention that after Sandy some pirates stole the mast and rigging off the boat. At least they left me the turnbuckles attached to the chain plates. Where woul I find the spreaders and cable rigging at a reasonable price? I'm doing this on a beer budget slowly and have found some new rigging for newer hunter models for sale (spares)!is there a site that will define the cable lengths
Jun 27, 2004
113
Hunter 34 New Bern, NC
I think you need to salvage a wrecked H 34. You may get this opportunity after hurricane season!
