336 prop size
SunHunter
SunHunter is on the hard. I have attempted to determine prop size, but there is a pit right where the sizing is stamped. I know it is a 13X something. Can anyone tell me what size prop Hunter put on these boats back in 1995-1996? Thanks
Dec 3, 2003
2,101
Hunter Legend 37 Portsmouth, RI
Check This Site
Select the "Boat Information" tab and then select your model and then "specifications". You will see the prop size. I would confirm this with a local dealer, or Hunter, to be certain.
Mark
Is it the same?
Are the manufacturer specs for a prop the same for folding and feathering props? Makr
Rick D
Jun 14, 2008
7,207
No, Mark...
Specs vary by feathering/folding prop depending on factors unique to each one. Normally, the seller dials in your engine/trans and hull specs to determine the diameter and pitch of their prop. RD
P
Pete
I have a Hunter 336 (1996) the factory prop is a 2 blade 1 inch bore 16x13 prop. Hope this helps.I replaced my factory prop with a 3 (fixed)blade 1 inch 16x12. Im very satisifed with the results. As far a folding or feathering you will need to go to the manufacture or there rep and let them size there prop for you.
David
Tell me more Pete
What has been the difference in performance between the two. Have been thinking of going to a 3 blade prop for my 336. David
