Just bought my first Hunter - a 1995 336. How many cans of VC17m bottom paint should I buy for this year's spring commissioning? Thanks in advance.Ned Strain sv/Family Therapy Chicago
I would suggest 4 qts. Depending on how you paint (spray or roll) 3 may do it, but would buy 4 just to be on the safe side. If you roll on, trying mixing the paint, then pour into a clean dishsoap bottle and use this to squeeze unto the roller as needed. This will help cut down on the amount of paint that evaporates into the air.Happy bottom painting.
I just used (rolled) two gallons of Micron CSC on my 336 bottom. One gallon will cover about 80 percent. The second gallon covers the rest and provides a thin second coat to catch the spots I missed.s/v windswept
I had a 336 till this year. If it already has been coated with VC17 once you should be able to get the job done with 4 to 6 quarts. It sort of depends on how neat you are. I have always rolled mine on some guys like to spray. Only pour into the pan what you can use in about 5 to ten minutes, this stuff evaporates very fast.
