B331 Quadrant
There is no question that the pressure fitting was loose enough that the rudder post was allowed to slip under heavy load. Even though 3 bolts were loose, the quadrant itself will not wobble or move due to the tension load exerted on it by the steering cable.The steering cable also had excess tension on it which I corrected at the point that I was satisfied that I had corrected the rudder problem.Now that I have the steering cables tensioned correctly the boat steers much better as well.Good luck. The B331 is a great boat, stable and sails well except in light air.I don't feel that the new line of beneteau's look as nice although the new Finot design 34 & 37 apperar to offer an improvement in performance in their cruising line.I have sailed along several B423's and they seem to sail particularly well even with a RF Main.Good luck.
