33.5 fuel tank leak
Sutric
Jun 24, 2021
48
Seafarer 26 Carlyle IL
Went out to our 1993 33.5 last Friday only to be greeted with an intense diesel odor. Tracked it down to the fuel tank having a puddle underneath it with some collecting in the sump aft under the quarter berth. This tank was changed 9 years ago with a new aluminum one from Ezell Industries who, I'm guessing, was the OEM supplier to Hunter. Traced the leaks down to two pinholes almost in the center of the tank. It looks to me like the holes are a result of internal corrosion. I was able to easily poke a small screwdriver though them and the metal looked really thin at the edges of the holes. I have a local welder who can weld these up but am I wasting my time and money by not knowing how bad the rest of the tank bottom is?
Jan 4, 2006
7,870
Sorry to say it's a waste of time. Whatever corrosion process caused the pinholes in that location is also at work causing porosity on the rest of the tank bottom. From what we're able to see of the two pinholes, your welder may not be able to find enough aluminum thickness to weld a patch over the pinholes. That also applies to any other proposed welding on that bottom.
RoyS
Jun 3, 2012
1,742
Was the tank bottom resting on damp plywood?
Sutric
Jun 24, 2021
48
It was sitting on plywood but it wasn't rotted. I couldn't tell you if it was damp because of all the diesel that leaked out.
Nov 6, 2006
10,256
Best to take the tank out and either replace with poly or another aluminum, or if the sides are OK, cut out the old bottom and weld in a new bottom plate. A doubler plate is not a good idea because water will get in the pinholes and get between the bottom and doubler and quickly corrode the doubler plate bottom.
Sep 4, 2007
795
Hunter 33.5 Elbow, Saskatchwen, Can.
How much trouble is it to remove the fuel tank? I've seen a few posts about tank leaks and wondering if this is in my future.
Sutric
Jun 24, 2021
48
It is a large PITA. Luckily for me the previous owner cut a large hole in the aft bulkhead that we could use to get the tank out. We also had to take out the batteries above the tank and remove the floorboards below them. As the tank was pretty full, we had to siphon out 16 gallons of diesel. Then, when all that was done someone has to lay on their side in the quarter berth and try to wiggle that thing through the opening. All in all, it took 3 of us about 4 hours to get the dang thing out and in the back of my truck.
RoyS
Jun 3, 2012
1,742
IMHO the correct way to support a new aluminum fuel tank is to bond plastic isolating strips to the bottom of the tank and to place the tank on a sealed plywood surface that has drain holes throughout. This is not my idea but one I found researching on line and applied to my own tank replacement. See photos below.
Sutric
Jun 24, 2021
48
Here is a picture of the new tank installed. I bought an off the shelf 15 gallon plastic tank from Moeller. Since it was smaller than the original tank the installation was much easier. It's resting on a bed of Dri-Decking. It was a bit tricky to get the vent and fuel fill hoses hooked up due to the limited space overhead but we got it done! Best part is that you can see the fuel level just by opening up the inspection port in the aft berth and shining a light on it. Feels good to have it running again.
4
Hunter 31 Ky Lake
Would you be kind enough to send me more information on 15 gallon tank. Also how did you get old tank out?
Thanks
May 16, 2021
4
Hunter 31 Ky Lake
Question? Has anyone cut a hole in top of poly fuel tank were you could clean the bottom of tank? If so what did you use to seal hole up with?
Jan 4, 2006
7,870
What do you expect to find in the bottom of a fuel tank ? If the fuel is properly treated with a biocide like Biobore, it should be clean.
Every so often I'll use the Pela oil extractor to go in through here and pull a sample to check for water on the bottom of the tank.
Any hand hole large enough to enter the tank is looking for trouble in the form of a leak.
dmax
Jul 29, 2018
1,362
Telstar 28 Buzzards Bay
I put a similar Moeller tank in my boat, 19 gallon, it's great. One thing I would caution you about is making sure the tank is secure and will not move about when sailing. See if the straps are enough to hold it from sliding sideways. Moeller sells some mounts that will help: https://www.amazon.com/Moeller-Perm...ocphy=9001873&hvtargid=pla-493053509998&psc=1
I have straps and the Moeller mounts and it still moves a bit from side-to-side so I'm in the process of building a wood beam to capture it on the side (one side is already against fiberglass). A full tank is pretty heavy. My original tank was captured on all sides by a plywood frame.
Likes: Hollyberry
RoyS
Jun 3, 2012
1,742
Agree with dmax, you need to keep tank from moving. Wooden strips fastened around the bottom edges will work. Lots of inertia there.
Sutric
Jun 24, 2021
48
Thanks
Sure, Here is a copy of the drawing that I got from Moeller. We detailed what was involved getting the old tank out above. Suffice to say it was a PITA! I don't know what would be involved in getting out of a 31. Good luck!
1,946
I used the stainless clips available by Mueller. The tank has recesses in it to accept the clips. Rock solid installation for me.
