322 Slamming off waves
Jul 15, 2014
73
Oday 322 Freeport, Bahamas
When I brought my new to me 322 home it involved a run across a rather rough Gulfsteam. She really slammed and I think I found much of the problem.
I was concentrating on the keel sump the last couple of days so had not gotten around to emptying out the anchor locker. What a surprise. I took over 250ft of rusty chain out of the locker.
That's over 400 pounds of weight right in the nose. No wonder she was slamming.
I know cruisers talk of all chain in their anchoring systems but she had all that chain plus two big but crap Danforth copies. I was amazed how they got all this in there.
When you plan your anchoring system don't forget to consider the weight in the bow.
Here is what I now have:
35 pound Delta with 50ft of chain and 100 ft 3/4 nylon rode
15 kg Fortress 20ft chain 100 ft 1/2 nylon
75 pd Luke Fisherman (disassembles and is packed in foam under the head cabinet)
In the lazaret I have two more 100ft sections of 3/4 nylon rode.
I've taken over 300 pounds out of the bow. This helped with both slamming and hobby-horsing.
Jul 27, 2011
5,181
Bavaria 38E Alamitos Bay
Wow--3/4" 3-strand nylon rode for a 322? I think your anchor would pull out long b/f even 9/16" 3-strand would part. What size is the chain? I carry only 5/8" 3-strand "back up", mostly in case I ever needed a tow in seas.
Jul 15, 2014
73
It is overkill for a 322. They are the anchors and rode off a Countess 37 center cockpit pilothouse that I sold to a guy in the UK. The new owner had his own anchors in the UK and didn't want any weight in the bow when we took her to England. Bahamas - Bermuda - Azores.
This 322 doesn't have a windlass and hauling chain is for young guys. In this area, it's unusual to anchor in water over 12 ft deep.
Jul 12, 2011
148
Oday 302 st pete
Im sure removing all that weight from the bow will help, but the bottoms on the 302/322 boats are pretty flat. That, I believe, is what the majority of any slamming is from.
RichH
Feb 14, 2005
4,773
The 322 is relatively 'flat bottomed' and 'fine bowed' boat ... for such when 'pitching' one has to consider to alter the sailing angle into & away from waves to allow longer timing interval for the bow/stern to rise, even if the ends are 'light' when the boat is 'slamming'. Decreasing the sailing angle into/from waves will lessen the impact timing from the 'pitching'.
Simple speak: foot off when slamming so that the bow/stern has a longer 'time' to rise. Adjust your sailing angle based on wave period and amplitude.
Jul 15, 2014
73
I'm familiar with that. The problem here - the stretch between Bahamas and Florida is often wind created waves combining with opposing current (3kts Gulfstream) waves. More like an agitator.
I have been out twice since I removed a couple of hundred pounds of chain out of the bow and it's much better. Appreciate your comments. There was a Tayana 37 anchored just behind me yesterday - nice boats.
RichH
Feb 14, 2005
4,773
I often sail the Straights of Florida and down between the Abacos and Berrys often. You really sometimes have to wait for a proper weather window or get slammed by the BIG chop and 'confused' seas due to 'mish-mash' of several intersecting currents and opposing winds.
All the weight you can remove from the ends certainly will help, so will 'footing off'. :)
Jul 15, 2014
73
Next time you're near Freeport, drop me a line and I'll buy you a beer. bahamasailing at gm@#l dot com.
