G
Gary
Installing a Raymarine combo Radar/GPS at the helm, radome antenna on the mast. From reading the archives, I see the best way to run the power is to follow the battery charger wires down the port side behind the microwave to the panel. However, I'm not sure about the radome wire. There is probably a better (shorter) route to the base of the compression post. I was thinking of going through the bilge? Has anybody made this run in the past? I get 45ft of cable, hopefully that will do it. Thoughts appreciated. GaryWanderlust #845
