320 Holding tank vent hose replacement
G
Gary
Due to nasty head odor, one of the things I'm checking is to see my holding tank vent is clear. What's the best way to do this? Also, while trying to trace the vent hose yesterday, I lost it. It runs off the top of the tank to the starboard side then disappears. Has anyone ever changed this hose? How did you get acess to where it connects to the stantion? Any thoughts would be appreciated.
Pat Tyler
holding tank
Gary, We had a oder problem which sounds like yours on our 320. Our vent is on the side however. I found that the vent was stopped up and after cleaning it out we switch to fresh water for flushing by using the shower/sink outlet. Also we switch to oderless. After several pumpouts with fresh water flushing each time the oder is gone. I'm not sure this helps since our vent is a little different that yours. Pat
Pete Peterson
Flush vent hose
Gary, I second everything Pat said about fresh water flushing and Ordorloss treatment. It completely cleared up my problem. My vent opening is on the hull, not the stanchion, but I don't see why you couldn't back flush the vent with a hose. Sea Chalet, #815
Jeff Church - Hull #535
Head odor
Gary, I had the same difficulty trying to follow the hose to the vent fitting. I was trying to check the vent because 1)I was getting an odor in the head, and 2)there was a lot of back pressure when pumping the bowl dry. Initially, I figured that the vent was clogged, but it turned out otherwise. I checked to see if the vent was open by pumping the head vigorously, and then quickly pulling the vent hose off of the tank fitting. There was no rapid escape of gas. When I tried the same with my finger over the tank fitting, the tank held pressure until I removed my finger. I eventually decided that the smell was coming from stale water in the head inlet hose. Others have reported the same problem. After I pump some water through the head, the smell dissapates and does not return until the system has been left unused for another 24 to 48 hours. Every time we open up the boat, I try to get the stale water pumped out before my wife or passengers get a nose full of that nasty smell. The back pressure was another problem. It turns out that there is a flapper valve in the pump which is supposed to be opened when the switch is moved to the "dry bowl" position. The switch was not opening the valve, and that caused a vacuum to build up behind the plunger on the down-stroke. Check the attached picture for a simple way to extend the lever. I would like to hear the manufacturers response to this problem as I know several owners that have the same experience with the Jabsco model that was used on the C320. JC
Ron
Are you using Seawater?
Gary I've found (and Peggy, our Head-Mistress will confirm) that stale seawater in the bowl & pipes can really stink. The water is full of little critters that die & decompose, giving off a sulphurous odor. It only takes a day or two in the summer for that stagnent water to turn bad. If you just sail weekends or every couple of days, try flushing with freshwater & some clear vinegar just before leaving the boat. The vinegar will work on the Uric Acid crystals in the pipes/etc. Peggy also recommended greasing the Jabsco pump periodically. She recommended a teflon grease rubbed around the cylinder lining. I tried that & the pump works ever so more smoothly now. --Ron --Ron
