315 Battery Meter
Jan 23, 2021
49
Catalina 315 81 Newport Beach
Our new 315 has three batteries (two large ones for the house and a smaller one for the engine starting). The battery condition meter shown above only has two positions. Currently (no pun intended), the meter shows the condition of the two house batteries as battery 1 or battery 2.
I think it would be more useful to have the meter show the condition of the engine starting battery as one of the options.
Has anyone with three batteries done this and could give me a hint about how to make it happen?
Thank you in advance for any advice...
Catalina 320 Dana Point
Are the house batteries not connected in parallel so they would read as a single battery, so Batt 1 is start and Batt 2 is the house "bank", both batteries ?
Skipper John.
what happens when you switch from Batt1 to Batt 2?
It is a guess, you would get the Voltage for Batt2 the Start Battery.
This is a scientific guess. You will need to inspect the battery connections for your boat. See where all the wires go. Tte crazy thing, previous owners can change the connections. So better not to guess and inspect your boat taking notes about how and where the wires ho.
Jan 4, 2006
7,870
I suspect your wiring is pretty much as described by @jssailem and @Calif. Ted .
An easy check is to get out your multimeter and see what each battery voltage is compared to your battery monitor. This will confirm if your system is wired as it should be. I got two nickels, a dime, and a ball of pocket lint that says it is.
Aug 2, 2009
651
Catalina 315 Muskegon
Ditto on what Ralph said regarding checking with a multimeter. My 315 (2014) has just the two 4D batteries and I have the same meter as you that switches to measure 1 or 2.
If I had that third battery, I suppose it would be nice to add a meter. Or I might be happy just checking it with my multi-meter now and then. If I was doing more extensive cruising and overnights, I'd add the extra meter.
P.S. To check your's, instead of using the multimeter to see which batteries the meter measures, you could just disconnect the starting battery and see if you get two readings. But you probably already thought of that.
Fwiw my 320 came from the factory mislabeled, the battery labeled #1 was really #2 on the meter and vice versa, suspected in use I confirmed by disconnecting a negative terminal and seeing result on VM.
Aug 21, 2019
163
Catalina 315 18 Grosse Pointe Park, MI
My boat, orginally came with two 4D batteries. They were pretty worn out when I took posession of the boat. I decided to go with 2 LiFePO batteries and an AGM starter battery. I had to isolate the LiFePO batteries from the AGM. The easiest way to do this was to connect the LiFePO batteries to switch positions one and two and not connect the AGM to the panel at all. Now, the LiFePOs charge through a DC-DC charger connected to the AGM. The DC-DC charger has a meter that I use to monitor the state of the AGM.
Anyway, my point is that the electrical system of the C315, at least in 2012 when my boat was built, was not designed for 3 batteries. Perhaps Catalina used a similar solution to my own.
7,235
CC 30 South Florida
It depends on how are the batteries wired. You could have the two house batteries wired in parallel to make up one battery bank and the starting battery sitting alone as a 2nd battery bank. House batteries are usually deep cycle batteries rated in Ampere/hours (Ah) while Starting Batteries are rated in cranking amps. The deep cycle batteries are designed for slow and deep discharges while the starting batteries are designed for large but short bursts of power. For those designed features these batteries are rarely mixed. While monitoring the house batteries yields a lot of useful information having to do with discharge limits, duration of power availability and scheduling recharges, while the monitoring of the starter battery is questionable. The starter battery uses a short power burst to start the engine and charges right back from the alternator. They are usually fully charged or faulty which you will notice with the speed that they will crank the engine. You mention two large batteries for your house but do not indicate the voltage. Many boats carry two 6V batteries which wired in series will give you 12V. These are big heavy batteries rated for around 225 A/h while the 12V ones are rated for 115A/H. Two of each will produce a battery bank of around 225-230A/h. You say the boat is brand new and I don't have any issues with how you say the batteries are monitored so I would recommend before making any changes that you familiarize yourself with your batteries and system and get to use the boat and see how the monitoring works for you. Simply put the starter battery should be always fully charged so monitoring it is irrelevant. Even when a starter battery goes bad it may still show fully charged to the monitor but receive a deep drop in voltage when subjected to a load. Usually listening to the starter cranking speed is the best monitor for the starter battery.
Likes: Skipper John
Mar 6, 2008
332
Catalina 310 Scott Creek, VA
Two 4D batteries were common on the C310 also. I replaced mine with four 6V batteries, and added a reserve (start) battery. If you will use your boat such that you are at anchor for several days in a row, with no charging source, you should consider wiring both 12V house batteries in parallel as a single bank. This will reduce the depth of discharge, and would also allow you to monitor both banks on your meter.
Jan 23, 2021
49
Thanks, All, for your help. I will have to do some more disconnecting and reconnecting to double-check things. The battery selector switches do not seem to affect the battery meter.
I was hoping that someone would know how a 2022 boat would come wired and how to make the best use of that built-in battery meter shown above. Fingers crossed (not wires!) John
Posted below is typical Catalina wiring, note the Voltmeter is connected direct to the positive of both batteries at the selector switch so IT is independent of switch position. Also note the bilge pump is likewise connected so as to be always live independent of selector switch position.
Likes: Skipper John
Jan 23, 2021
49
Brilliant! Thanks for finding that schematic.
Aug 19, 2022
7
catalina 315 Lake Diefenbaker
Skipper John, it all depends on what position your selector switches are in. If the engine selector switch is in position 1+2 then the starting battery is in parallel with whatever battery or batteries are selected by the main selector switch. If you want to measure the voltage on your starting battery, you can move a wire.
Unscrew the switch panel (after disconnecting your batteries of course) and move the small gauge (orange on my boat, not purple) wire from position 2 of the Main Battery Selector switch to position 1 of the Engine Selector switch. The battery condition meter will show the starting battery voltage provided the Engine Selector Switch is in position 1 (and the panel is powered by the Main Battery Selector switch.)
If you want to be sensible, move the other small gauge (orange? Purple?) wire from position 1 to the C terminal on the Main Battery Selector switch. Then, when the Engine Selector switch is in position 1, one position of the battery condition meter will give the voltage of the starting battery and the other will give the voltage of the house batteries as selected by the Main Battery Selector switch.
If you want to just use a hand held volt meter, make sure both those switches are OFF. Otherwise, some or all of the batteries will be connected in parallel.
For the record, our boat is a 2018 Catalina 315, hull 61.
John, are you suggesting you do NOT have a manual for your boat?
I strongly urge you to obtain one.
And for all the guessing going on here, just open the panel and your battery box and trace the wires. Ralph's right.
Aug 19, 2022
7
Stu, the Catalina comes with a manual. John likely has that manual, a blue binder. Problem is the manual is generic. Every boat is built one at a time. Some options are added at the factory, some by the dealer. No guarantee it’s wired like the generic options given in the “blue manual” if it’s a dealer add on.
Yes looking at his batteries and switches is the only way to be sure. But it helps to know what other people have discovered and what they did to obtain a different result if one is desired.
Shutting down conversations about what other people did is unhelpful and unnecessary. I’ve solved a lot of problems by looking on forums just like this one.
I fail to see how anything I suggested could be remotely construed in such a manner.
I have owned my C34 for 25 years, and a C22 & C25 for 15 years before that. I understand how manuals work and am grateful to Catalina for assembling some of the best boat manuals in the galaxy. :)
The "basics" of the contents Catalina's manuala, in my more than limited experience, are 95-100% correct and valid.
For something as simple as this exercise, I simply suggested he go look, for exactly the reasons you mention. :)
Aug 19, 2022
7
I guess I misunderstood you.
We are huge Catalina fans. Had a Catalina 28 mk II. Manual covered everything because it was a pretty simple boat really. When we decided to buy a new one, it had a be a Catalina. Only decision was a brand new 315 or a used 355.
Modern Catalinas have become complex. Large option list. And as I said not always clear who installed what. So the manual covers some options but not everything and all bets are off if the dealer installed it.
Our batteries were not connected according to the manual’s wiring diagram. Maybe it was out of date. Maybe the dealer installed the starting battery. Warren the support guy at Catalina is wonderful but I decided not to bother him with it. We figured it out and figured out how we wanted to change it, right down to fixing the battery condition meter so it reads what we want it to.
I have to admit fixing all the new boat problems — and yes, there are always new boat problems and we are nowhere near any kind of business that services sailboats — has been an excellent learning experience. So years from now when we have old boat problems we will know where everything is
