Paul, are you telling him to be sure the battery charger is turned off? All that would do is change the voltage being measured, and can be done from the electric panel at the nav station, maybe more easily. Regardless, when the ignition switch is turned off, there should be 0 volts at the panel meter.Make sure your AC aft end switch is off position.
paulj
