310 information
paulj
Mar 16, 2007
1,361
Catalina 310 Anacortes,Wa
Over the past few months, my engine has developed a coolant/antifreeze leak in the closed cooling circuit. The leak is at the aft end of the engine. I haven't eliminated the leak just yet, but wanted you all to be aware of four sources for such a leak: . One source is the coolant drain, which takes the form of a small bronze screw next to the pencil zinc on the bottom starboard side of the heat exchanger. This tends to wiggle itself loose over time. Check it regularly. . A second is the connection of the thick wire-reinforced manifold hose to the heat exchanger. Apparently due to the thickness and stiffness of the wire reinforcement, it can be difficult to get the hose clamp tight enough. Touch a paper towel to either of those points to see if there is moisture. . Third, the plastic coolant surge tank tends to crack next to the hose nipple at the bottom. If yours hasn't cracked yet, definitely check it out. . There is a separate source of leaking for 310s built prior to mine in 2002. It seems that earlier heat exchangers were attached to the engine by means of a bracket that could be a point of corrosion. Our 310 Association Tech Editor, Bill Lewis, did a terrific job in the Mainsheet describing his work to resolve this issue. Just go to http://www.catalina310.org/MainsheetMagazine.htm and pull up the 2004 and 2005 tech notes articles. Finally, I researched a bit the recommended coolant/antifreeze for the engine, since Westerbeke does not specify one. All you guys in the frost belt probably know ALL about this, but it's not such a point of discussion in more temparate climes. First, use propylene glycol rather than the toxic ethylene glycol. My authorized Westerbeke diesel mechanic prefers to use a Dex-Cool extended life coolant, which he purchases from an auto supply place, and he says it is fine to use it up to five years between changes. He notes that our engine will cycle hot and cold much less frequently than an automobile engine, and our engine operates at 160 degrees rather than the hotter automobile engine around 220 degrees. However, West Marine's 1-gallon Seafit Antifreeze and Coolant is fine. It's easy, though, to be confused with the antifreeze that is used for winterizing head and potable water systems, which do not contain the anti-corrosion additives of the engine antifreeze/coolant preparations. Our coolant system has about a one gallon capacity. Make sure to follow directions for dilution with distilled water. I understand part of the importance for this is to avoid concentrations that can damage gaskets and other soft parts. Notwithstanding my diesel mechanic's practice, Westerbeke recommends a coolant change every two years. There was a good discussion on this email list in April 2004 from Jon White, Gary Malcomson and Pete Sandford. At the time it was noted: The trick of bleeding the air out of the system after refilling, was to fill, run the engine, loosen the valve near the thermostat until coolant comes out, and repeat as many times as needed (about 3 or so). I wasn't succsesful the first several times, and the engine would quickly over heat. I was very frustrated until I started really racing the engine (to about 2,000 rpm). That seemed to push the air out and every thing has been fine since. Other good links: . West Marine article on antifreeze: http://www.westmarine.com/webapp/wcs/stores/servlet/westadvisor/10001/-1/100 01/Antifreeze.htm . Detailed Sailboatowners coolant thread: http://archives.sailboatowners.com/pviewarch.htm?fno=400 <http://archives.sailboatowners.com/pviewarch.htm?fno=400&sku=2007302170908. 96&id=499705&ptl=Anti-Freeze%20%22Color%3F%22&id=499705> &sku=2007302170908.96&id=499705&ptl=Anti-Freeze%20%22Color%3F%22&id=499705 . Westerbeke FAQs: http://www.westerbeke.com/technical/faq.cfm#38 PAUL V. OLIVA, Skipper and ASA Instructor Time & Tide, Catalina 310 #179 South Beach Harbor, D-79, San Francisco Oliva Global Communications 442 POST STREET, SUITE 800 SAN FRANCISCO, CA 94102 USA +1.415.235.5185 www.olivaglobal.com <http://www.olivaglobal.com/> SKYPE: olivaglobal
Good input, Paul
Regarding your issue with overheating, see this link from earlier today, it could be that you have an air bubble in the line to your hot water heater. See my last reply (#8) to John about "burping": http://www.sailboatowners.com/forums/pviewall.tpl?fno=21&uid=73200280089&sku=2007332212652.1&rid=2007333111819.12#2007333111819.12
