304 vrs 316 stainless
Jan 27, 2008
3,092
ODay 35 Beaufort, NC
MECHANICAL PROPERTIES OF TYPE 304 AT ROOM TEMPERATURE
Typical Mechanical Properties required for annealed material covered by ASTM A240.
Yield Strength .2% offset = 30,000 / Ultimate Tensile Strength = 80,000 / Elongation = 50%. Hardness R = 90 max.
MECHANICAL PROPERTIES OF TYPE 316 AT ROOM TEMPERATURE
Typical Mechanical Properties required for annealed material covered by ASTM-A240. Yield Strength .2% offset = 30,000 / Ultimate Tensile Strength = 80,000 / Elongation = 50%. Hardness R = 90 max.
TYPE 316 STAINLESS STEEL
Type 316 is an austenitic chromium-nickel stainless and heat-resisting steel with superior corrosion resistance as compared to other chromium-nickel steels when exposed to many types of chemical corrodents such as sea water, brine solutions, and the like.
Nov 9, 2008
1,338
304 & 316 share most of the same characteristics. same yield strength, 25000 PSI. 304 is a touch harder, but not much. But 316 is more corrosion RESISTANT than 304. The hardness may explain a little bit about the difference in galling but I would be surprised if that was true.
Any time you have a question about materials, go to McMaster-Carr. Search for "Stainless Steel" (in this case). Near the top of the page you see "About Stainless Steel". This opens up a page showing all sorts of information on the material. I've used this for years in engineering as a quick reference for designing with stainless, aluminum, rubber, plastic, copper, brass. All sorts of things. The information isn't textbook gospel but it can help you make a more educated decision on the materials and fasteners that you are considering.
https://www.mcmaster.com/#standard-stainless-steel-rods/=15w9e81
