"T" does not stand for "trunk"
I did a lot of research on this a couple of years ago; see the archives under "the mysterious Hunter T"Some say the T stands for trunk, others the cockpit layout, but it actually stands for the change in the serial numbers.The interior is the same, with a few exceptions (batteries and holding tank in difference places, trim package a little nicer).The rig is ALMOST the same. The backstay is a little further aft on the T models. The rest of the measurements are the same. The sailcover should be the same. Check the photos in model section, and you can see the difference in the backstay plainly. I should know, my sailmaker just got it wrong, and had to remove a couple inches from the roach of my new sail because it hung on the back stay...
