3 recessed lights above the compression post.
Jan 12, 2016
273
Hunter 410 Ladysmith, BC
Hi Everyone,
I've got a Hunter 410. There appear to be three lights that are on the headliner that triangle/surround the compression post. There are no switches to turn them on/off that I can see. I've turned on all the cabin/courtesy circuit breakers and they don't light up.
Is there a switch that I'm missing here?
Jun 4, 2004
1,087
Mainship Piliot 34 Punta Gorda
There should be a switch in one if the lights. Can also provide some help if you want to convert all those g4 bulbs to LEDs.
Without a pic I'm just guessing but on my hunter 26 you rotate the lense of the light itself to turn them on and off.
Jan 12, 2016
273
Solved! The switch isn't on the lights themselves but is on the pedestal support for the dinning table.
